starting savage 25
Discussion in 'RC Offroad Forum' started by Davemc, Feb 3, 2004.
Thread Status:
  1. Davemc
    Davemc Member
    I just ordered a new Savage 25, I could not wait any longer. I can not afford to get a battery and charger for the starter, so my question is;
    can I hook the steel shaft of the roto starter to a drill to start it?
    is ther enough room? will it hurt the motor?
  2. jlmoreno911
    jlmoreno911 Member
    TOYS R US has a charger and 7.2v 6 cell battery for $19.99
    I think that is your best bet...
  3. dudex
    dudex Member
    yeah you could do that, just dont spin it too fast.
  4. Davemc
    Davemc Member
    I AM maxed out for a bit, I had to buy my truck on the Canadian side, and it was allot more
  5. rcosmax
    rcosmax Member
    Using a drill to start your .25 is ok, try to use a drill that has a clutch so you dont force it to hard. also do it at a slower speed and only for a one or two count. put some after run oil in there first and also heat the block up with a hair drier and it should start right up for you first try. good luck and great truck!
  6. Davemc
    Davemc Member
    after run oil First? is this for break in or all the time?
    I do have a nice small cordless drill with a clutch
  7. rcosmax
    rcosmax Member
    put the after run in there first cause you dont want to start it up dry. make sure it is all lubed up. Ill say some more and if you are confused pm of email me. The s.25 engine had a problem with the backplate vibrating loose check on the bottom of you box for an x mark. if there is a big x it mean the problem has been fixed. but but but, with any car i get i like to take it apart before and check to make sure it is all together right, id take the ening e out easy 4 bolts reached from the underneeth, go and buy some high temp oxygen safe copper silicon from walmart. take the back plate off (be careful not to loose the little spring and rod that connects the oneway to the crank shaft) spray a little after run oil in there, and put a tiny bead (just a little) around the flat part of the backplate to seal it up. when you put it back together and slide that backplate back in there make sure it lines up with that little rod and goes together easily you shouldnt need to force it. use a little lock tight on the bolts and youre done. this will make sure that you dont have any air leaks and your engine will be easy to tune. This is not only for the savage! I do it to all my engines so dont be scared. PM or mail me and ill help you do it if you are worried. It sounds difficult but its not. good luck you will love that thing its an addiction. Email any time ill help you out.
  8. jlmoreno911
    jlmoreno911 Member how is it going with your savage??
    You out there having fun yet or still trying to get it started?
  9. Davemc
    Davemc Member
    Stil waiting for it to come in the mail, I dont expect it to come untill next week, I just paid for it today :-(
Thread Status:
