square or vanderbuilt?
Discussion in 'HO Scale Model Trains' started by nachoman, Aug 3, 2008.
which should I use, the vanderbuilt or the square tender?
  1. vanderbuilt
    9 vote(s)
  2. square
    22 vote(s)
  1. nachoman
    nachoman Guest
    I've picked up an old Mantua 4-4-2. It needs a few details before I put in on the layout, and I am debating wheter to swap the square tender with an old MDC vanderbuilt tender I have left over. My layout era is 1918, and my other locomotives for my fictional railroad will all have square tenders. But, my railroad interchanges with the SP, and I am considering pretending that the 4-4-2 or a spare tender was aquired from the SP, or possibly just having an SP passenger train to run on my layout.
    Either way, i like the look of the vanderbuilt - it's something different and it is already set up as an oil-burner. So what do you all think? Which looks better, the square or the vaderbuilt tender?
  2. Squidbait
    Square. Those little vandys just look, well I was going to say "silly", but "wrong" works too. That little Atlantic just looks unbalanced with the vandy tender.
    'round these parts, it was only the bigger (Mountain, Northern) types that got the Vanderbilt tenders... everything else had the squares.
  3. doctorwayne
    doctorwayne Active Member
    Yeah, I also think that the square tender looks better, mainly because that's a good-sized Atlantic. The Vanderbilt tender looks too small for that loco (and I'm a fan of small tenders).
    That MDC tender would probably look good behind one of Bachmann's high-drivered Ten Wheelers, the tender of which, in my opinion, looks too large.
    In my case, rather than shorten the tender, as I usually do, I'm going to make the loco larger. ;):-D
  4. CRed
    CRed Member
    Square,for the same reasons already stated above.
  5. UP SD40-2
    UP SD40-2 Senior Member
    Kevin, i am a BIG vandy tender fan:thumb: , but i gotta go with the others, the square tender DOES look better on that engine:winki: .
  6. shaygetz
    shaygetz Active Member
    Aye...so I'm the only vandy fan out there...I go crawl under me rock now.:mrgreen:
    Wayne, my dearest wish is to be shrunk to HO scale for an hour, just to take the throttle on your layout in one of your well finished steads.:thumb:
  7. doctorwayne
    Thanks for the compliment, Bob, but that could be a dangerous job: all of my locos contain quite a bit of lead. :eek:;):-D:-D
  8. ocalicreek
    ocalicreek Member
    Kevin - that's a fine looking little Atlantic regardless of the tender choice (the vandy does give it that SP look, however). Did you repaint it or is that the original finish? And where did you find a Mantua 4-4-2 that wasn't a PRR E-6 (with the Belpaire firebox)? I've been keeping my eyes on ebay to see how much they run and they seem to be quite rare.
    Also, if you're into Mantua (and my apologies if I've already shared this link a dozen times) you need to check out:
    Also, follow the link to the Yahoo group.
  9. nachoman
    nachoman Guest
    From what I can tell, it is all original mantua. It's not one of the oes they produced in later years that has the extra details; this is a plain Jane. I picked it up at a train show for 15 bucks, and it runs fine. Atlantics are my favorite steam wheel arrangement because they are unusual, yet very imortant in the development of steam technology. I also like that "short stubby" appearance.
  10. Sarge_7
    Sarge_7 Member
    I agree, usually I love a Vandy but....
  11. Kanawha
    Kanawha Member
    I like Vandy's, but they look better on larger engines, like 4-8-2's. Besides, Atlantic's have such a graceful, balanced look, a simple square tender fits them well. Btw, if anyone knows where I can find a C&O Atlantic in HO scale, I would dearly love to know.
  12. shaygetz
    That's OK...I don't wet my bed with the latest reports from the CDC---bring it on.:mrgreen:
  13. Triplex
    Triplex Active Member
    SP did have Vanderbuilt-tendered Atlantics, but I think those tenders were bigger. I like Atlantics, and I like Vanderbuilts, and therefore I like SP Atlantics. But in this case, the Vandy is too small.
  14. Squidbait
    Is that one of the first-run 10-wheelers? All the ones I've seen have the small tender:
  15. brakie
    brakie Active Member
    I think she looks beautiful with a vandy tender..That square tank makes her look-well-ugly.
  16. Squidbait
    How can you have such great taste in track plans and lousy taste in locomotives? :p :cry:sign1
    Besides, it's supposed to have a square tender:[​IMG]
  17. doctorwayne
    Yeah, the two that I've got are from the first run. As far as I know, the small tender, which would've been my preference, wasn't available with the high-drivered version. My original intention was to make two CNR H-6s, but the driver spacing is wrong as are the cylinders, and the boiler is undersize, too. My next thought was to use them to build NYC 1290 and 1291, the two F-82s that ran out of St. Thomas (with small tenders and auxiliary tenders), but the drivers are too tall. The low-drivered version, like the one in your photo, is a very close starting point for those locos, though, and I may do them after the current crop of rebuilds gets done.
  18. brakie
    Perhaps she looks sleek with a Vandy?
    I have a great taste for boxcars to.:eek:sign1
  19. nkp174
    nkp174 Active Member
    I don't like either tender. I do like the tender in the picture Squidbait posted...that's the tender I have behind my Santa Fe 4-4-2...and I'd look for something more like that as well (or, bash it!)
    I think the vandy just looks wrong...and the conventional tender looks like it belongs behind an 1890s 4-4-0.
  20. Russ Bellinis
    Russ Bellinis Active Member
    In the picture Squidbait posted it looks like the side of the cab is lettered for AT&SF. MDC made a Santa Fe type tender that is correct for a Santa Fe locomotive. I think you would need to find a prototype photo of an S.P. Atlantic to see what tender they ran with it. Even if you don't model it as an S.P. prototype, pictures of 4-4-2's with various types of tenders would give you a good perspective of the size for the tender that would be appropriate. I think most 4-4-2's were used in high speed passenger service in the flatlands. As a result of that type of service, they would tend to run bigger tenders compared to engine size than you might find on a 2-6-2 or Mikado.
