ezdays
Out AZ way
OK, the two new challenges are open, we're going to call them "Spring 07, scratchbuilt challenge", and "Spring 07, kitbuild challenge." The reason this sub-forum was created was to keep all the current contest and challenge entries together. We are expecting quite a few and I didn't want them to get mixed up with previous challenges. The rules for both these challenges are as follows:
Good luck to all that enter, we're looking forward to seeing what you have in store for us.:thumb: :thumb: :thumb: :thumb:
- Each person entering should start a new thread there in this sub-forum. The title of their thread should be,
"(username), Spring 07 scratchbuilt challenge",
or"(username), Spring 07 kitbuild challenge". - You can show pictures in your thread of what you intend to build, progress pictures and reports and comments from others are welcome.
- Get a photograph of a structure, any structure, then scratchbuild or kitbash a model of that structure. The idea is to come as close to the real thing as you can. The picture of the original structure does not have to be taken by you, but you must also post a picture of it, or a link to it if you found it somewhere on the Net. The surrounding scenery and details, such as people, vehicles and trees need not be the same, but it can be. However, the structure needs to be as close as you can get to it. Any scale (except full
- Just build a kit using only the parts in the box for the structure only. You may paint and weather the structure and make cosmetic changes, but you cannot add anything that does not come with the kit. You can though, add other details as scenery around the structure. This will allow you to do from a "let it look like the picture on the box" to "I built it like the instructions says, but I've enhanced it with weathering, different paint and scenery" to "I used all the parts in the box and this is what I came up with". The choice is yours.
