Spi's model - Westland Wywern
Discussion in 'Aircraft & Aviation' started by NOBI, Jun 16, 2005.
  1. NOBI
    NOBI Active Member
    Hi there,
    a break before begin next project, i decide to purchase Westland Wywern from Sipshop, 4.50 euro for a very good model in scale i want. after study instruction diagram so let's the rock begin.
    i begin with a part number1 (i alway build follow through sequence number of part, from 1,2,3,4,5...because that is a way what designer guide to you what u must build first) what is a propeller...this bird have 2 propeller what have 4 blade each...i only build a propeller's hub and i left blade to install later.
    after that i see an instruction, they guide me to make a wheel well :? i think no need to do that wheel well for now so i skip it to build a cockpit what i ithink it is important than wheelwell now. everything fit very well with a good color registration.
  2. Bowdenja
    Bowdenja Active Member
    Hey Nobi,
    I'm glad you got this one............. I've enjoyed building it myself. I'm almost finished and I've even put together one of your Seafurys to go with it!
    As usual I've built my to give away and it is not as detailed as yours will be. So I'm looking forward to your build, I know you will do this model justice.
    I also like that your are designing the tank T-55. It is looking VERY GOOD!
  3. NOBI
    NOBI Active Member
    Hi There,
    come back from T-55 and continue assemble Wywern, now i finish whole fuselage...parts fit very well but u need to sand an internal former to fit fuselage skin.
  4. NOBI
    NOBI Active Member
  5. yaniv
    yaniv Active Member
    g8 job clen work
    u can please send me link of this models or the cover of it?
  6. rickstef
    rickstef Guest
  7. NOBI
    NOBI Active Member
    work more on wing, i decide to make this bird in fold wing state. task begin with create wing's spar and wrap wing's skin into.
  8. NOBI
    NOBI Active Member
    another pictures
  9. mOONwOKA
    mOONwOKA Member
    Nobi, Your work is admirable. Builder's skills are adequate to model's quality.
    As soon as I saw this build, a little PVA devil started to whimp - buy one for me... pppplease, buy one for me!
  10. Bowdenja
    Hey Nobi,
    The build looks great! I'm planning on doing it again with the wings folded.
    This will be a great education experience for me!
  11. NOBI
    NOBI Active Member
    continue assemble :) today work on wing again. i had install wing into fusleage and found that wingspar is too long :) so i must cut it into 2 pieces and then install. assemble the rest of wing and some airscoop in front of wing and exhaust pipe behind wing in this time.
  12. NOBI
    NOBI Active Member
    More picture
