Spectrum 8-40C Performance
Discussion in 'N / Z Scale Model Trains' started by Flyboy41, Aug 10, 2007.
  1. Flyboy41
    Flyboy41 Member
    Hey all,
    I just want some reviews on the Spectrum 8-40C. I have a Spectrum 8-40CW and I don't think it looks too realistic and doesn't run slow enough. Anyone have opinions?
  2. Catt
    Catt Guest
    I've had some good ones and I've had some bad ones and then I've had some really BAD ones ,solved all that trouble with KATO U30-Cs and C30-7s.Well actually just the mechinisms cause those Bachmann's are the only show in town and if you want dash 8s you can overlook the cosmetic flaws if you can make good runners out of them.
  3. nscaler711
    nscaler711 Member
    I have had one she wasnt a bad runner all she had was a noisy motor which can be fixed with a Masima motor.
    and some lube.
    The newer ones look good (not a Kato or PCM good but cheapo company good.)
    I will be getting my seconod in a few weeks so i will show pics here if you would like but i say before you buy it make sure you test run it because Bachmann has good and bad eggs sometimes.
  4. Catt
    Catt Guest
    I couldn't agree more about the test run though I strongly suggest test running any loco by an manufacturer before laying out your hard earned cash.
  5. SeriousSam
    SeriousSam Member
    i have some of the older dash 8s with the older mechanism that run just as good as the ones with the newer split frame mechanism. I love the detail that bachmann has added on the newer models. Overall, the newer mechanisms are not bad.
  6. b28_82
    b28_82 Member
    If you want a decent running and better detail dash 8 and can settle for a 4 axle then look for the atlas ones that came out a couple years back Atlas Model Railroad Co.
  7. darkcurves
    darkcurves Member
    I'm a big fan of 8-40c. Got one from Bachmann, the old run and it's terrible. It was smooth and quiet but quality is terrible. The worse happened when the holes for the screws which holds on the cover to the chassis got bigger. Means i can screw the body back. Then all of a sudden the loco just stopped working. I tried tried to fix, still cant do much. After this experience, not sure i should spend 70 bucks on a new run or not. Just hoping Atlas or Kato will come out with 8-40c.
  8. Flyboy41
    Flyboy41 Member
    I too with Atlas or Kato would come out with a good Dash-8-40C. I know Atlas makes a good four-axle Dash 8.
    I'm really leery of buying any locos that isn't Atlas or Kato myself.
  9. Ray Marinaccio
    Ray Marinaccio Active Member
    I have both and old run and the newer run of the Bachmann Dash 8.
    I had to do some tweaking to the older one to get it to run right.
    I am impressed with how much better the the newer design is.
    If you are having problems with an older one I would suggest sending it back to Bachmann for replacement with the newer model. It's worth the service charge and postage.
