soldering track?
Discussion in 'Getting Started' started by rogerw, Jan 26, 2008.
  1. rogerw
    rogerw Active Member
    Im in the process of soldering my flex track and have a question. Is it worth staggering where i put my rail joiners? Should I just solder where the two meet (inner , outer rail) or push the floating rail down the ties about 6 inches or so? That way the inner and outer rail joints wont be next to each other. Would this help with running?:p(<i just like this face:mrgreen:) thanks in advance
  2. steamhead
    steamhead Active Member
    Staggered joints help to prevent a kink in the track on the curves...Even on soldered rail there can be a tendency to form a kink there.
    Rule of thumb (for carpenters)...Stagger the joints...!!
  3. rogerw
    Thanks Gus
  4. 60103
    I staggered the joints on one layout -- never again. You end up with to many places where you have to cut clearances for rail joiners a few (or many) ties into a length.
    I might do it where I start one side with a half-length of rail and the other with a full length.
  5. MadHatter
    MadHatter Charging at full tilt.
    Why not check out the Gauge E-mag, there is an article in there 'bout soldering. :)
  6. nachoman
    nachoman Guest
    I don't think this is necissary. Sure, staggered joints makes things smoother, but from my experience, if you solder while the joint is straight, and then bend, the joint winds up plenty smooth. In other words, start bending the piece around the curve. Hold it with tacks for track that doesn't hold it's shape. When you get about 4" from the joint, leave the last 4" straight and cut the long rail off to be approximately even with the short rail. Now, solder the next piece of flextrack on, and then keep bending around the curve.
