soldered joints
taylor_up_bnsf
taylor_up_bnsf
Dec 9, 2007
23
Arizona
I have finally started my layout. But I was wondering if anyone had pictures of the joints were two peices of track were soldered? Seeing as this would be a great help as this is the first layout I will be building.
DeckRoid
223
Caldwell, ID
Soldered flex track? Snap track? EZ track? I have tried my hand at soldering the connector leads on my flex track.
Every 2 sticks are soldered together (or if you like, every 6 feet has a soldered lead going to my wiring under the bench).
I will try to get some pics.
doctorwayne
3,516
Canada, eh?
Properly done, it shouldn't look too different from a rail joiner that hasn't been soldered. If the area is clean, then heated quickly and thoroughly, the solder will be drawn into the rail joiner, bonding to both it and the two rails.
Wayne
jeffrey-wimberl
2,564
Sundown, Louisiana, USA
This photo shows a soldered rail joint. A small amount of non-acid paste flux was brushed into the rail joiner just before the track pieces were joined. When the pieces were properly set a hot soldering iron was applied to the joint and solder applied. The solder followed the flux into the joiner, effectively welding the joint together. If it's done properly, the soldered area should be nearly invisible, as this one is. This is a typical soldered joint on my layout.
hickstmj
Marcie
Jan 28, 2008
138
Florida Panhandle
Pardon me if I am "hijacking this thread". When soldering wire to track how do you hold the wire, the iron & the solder at the same time? I seem to be one hand short.
doctorwayne
3,516
Canada, eh?
Tin the track and the wire first, then hold the wire to the rail with a small screwdriver or similar tool, while applying heat to the railhead.
Wayne
b28_82
419
Midwest City, OK
www.geocities.com
one thing I do is bend the wire so that it'll naturally lean on the rail when i'm holding the wire from beneath. Then your other hand is free to use the iron. As for the solder I have what i need on the iron already which isn't much.
DeckRoid
223
Caldwell, ID
I have had success with both Doc's way and b28_82's way. Sometimes I can tin wire and track with no issues, other times, I use a paperclip bent around to hold the wire in place.
Of course, after melting some track, I just went with track connectors with leads and soldered them together.
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Tinning the track and wire is the best way. I also pick up a bit of solder on the end of the soldering iron. One thing I have learned over the years of soldering is to hold onto the wire. You should be able to solder the joint quickly, so if the wire starts to burn your fingers, you are using too much heat or you're holding the iron on the joint too long. The insulation will melt or you'll wind up with a bad or "cold" solder joint.
It's also possible to hold the wire and the solder in one hand, but it's tricky and takes practice.
L
lester perry
Iwould love to learn to solder with one hand. My left hand is not very steady since the stroke.
Les
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Les
The make soldering helpers, some have an alligator clip on the end of a metal snake which is mounted on a weighted platform. The clip can be moved in any plane and can be used to hold the wire or one of the pieces to be soldered in just about any position. The clip also serves as a heat sink. That might make things a little easier for both one or two-handed soldering.
L
lester perry
I use the helping hands all the time but that is not useing on hand to hold solder and Iron in one hand. wait a minute here . Easy Days/ Don did you edit your original post to make it say hold WIRE and solder in one hand or am I mis reading things.
Les
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Les
No, that's the original statement. It takes practice, but I've solder so much in our business that I used to hold the wire between two fingers, wrap the solder around my thumb and feed it to the joint. Things went a lot faster and easier if I had someone to feed the solder though... Better yet, if I could get my wife to do the whole job, that worked even better.:mrgreen: :mrgreen:
Doing the whole thing with one hand, no way.:eek:
L
lester perry
OK I miss read it. that sounds better. I was ready to ask you where you live so I coud go to your house for tudoring.
Les
hooknlad
396
Woodbridge, NJ USA
Don, is there any way that you could link this forum to the already well established forums on soldering? That forum is a fabulous one stop shopping for soldering. It contains many great suggestions from some of the best GAUGERS around, and i guarantee it will help anyone who is interested in this subject. thanx again and Im glad to be back.
