Smoke unit repair???
Discussion in 'HO Scale Model Trains' started by XavierJ123, Mar 2, 2005.
  1. XavierJ123
    XavierJ123 Member
    My 4 year old grandson damaged a little Bachmann 0-6-0 which I managed to repair after three days of exasperation.:mad: It runs again but the smoke unit is not up to par.:cry: I took it apart again and noticed two thin wires from the headlight didn't seem to connect anywhere. :( Also, there is a teeny tiny black post in the center of the little square smoke unit with some more small wires attached to it from both left and right sides. Do these wires have to be "positioned" or "connected" in a certain way to heat up the liquid smoke more efficiently? :confused:
  2. knk
    knk New Member
    My 5 year old son stuck something down the smoke stack on a 4-8-4 Backmann. I took it apart. The two wires that do'nt seem to connect are the same on mine, they are the headlight which still work.
    My problem is he severed one of the 2 tiny wires strung around the heating posts, so now it can't heat up the smoke fluid. I hope I can order a new unit.
    Anyone have any advice??
  3. up_santafe
    up_santafe New Member
    Bachmann has a lifetime warranty. I would send it back for repair/replacement. Their service has been excellent for me.
  4. petey
    petey Member
    You can repair the unit. The light wires do not "connect" to anything. They are pressed against the two halves of the engine weight, which carries the operating current. Once the shell is replaced on this weight, it should press the wires down onto the weight halves, one wire on each half. The wires on the smoke unit must contact this weight in the same way. The two "ears" on the smoke pot, are there just to make contact with its adjacent engine weight half. Manufacturer causes this to happen by winding one wire from the center post, so that the wire winding becomes thick enough to make contact with the weight. The plastic in these pots is attacked by the smoke oil, so that eventually the "ears" weaken and break at their atachment point. When this happens, although they may look OK, they aren't making contact. The fix here is to unwind the wire, discard the ear, loosen the weight screw(holding the halves together)and cram the wire between the pot sides and its respective weight half, w/o breaking it; tighten the weight screw, and you should have firm contact on each side. If the wire running from the center post is broken, it can be soldered with a tinned, fluxed, hot iron(flux the wire halves also). Touch the iron briefly to the wire.
  5. XavierJ123
    XavierJ123 Member
    Thanks for the instructions. Now all I have to do is find time to do it. Thanks again.
  6. knk
    knk New Member
    Well, rather than sending it in and having the down time I went ahead and bought the Seuthe smoke unit which was very quick to install and much better smoke. I liked it so much I bought another one for the Big boy. They were so easy to install.
