Small 4 x5 around the tree layout question
shaygetz
3,612
www.freewebs.com
jflessne said:
:) Too small a layout to have more than one train. But it might be challenging to run multiples on it.
But not too small for two trolleys...:thumb:
The house only needs a little accenting of the shingles to set it apart from an R-T-R look, an India ink wash with some drybrushed light grey will do wonders. Maybe Granny on a rockin' chair and Rover at her feet on the porch?:)
How's the crossover working for you, especially at the rail joints? Is the transition smoother than the picture tells?
BTW...twern't ignorin' ya jes' busy settin' mine up, too.:thumb:
jflessne
165
Hot Arizona
www.azlivewire.com
I mentioned in an older thread I installed the pond using white glue. I created a silicone berm on the outside of the pond to simulate snow banks. Later it will be covered by snow. Then I simply put down a thin layer of white glue. Before it dried I stuck in a few rocks from our rock yard and a few sticks. In an effort to keep my 3 year old involved in the project I allowed him to add some ballast to the outer edge of the pond. It didn't turn out so great as the ballast quickly oozed into the inner part of the pond. :(
The end result was a pretty cool pond. However I wish I would of painted the foam a bit better before starting the pond. The pink foam seems to cast a hue on the pond. :( By someones suggestions I will add another layer of glue and maybe some white paint.
I realize now I grabbed the wrong size ballast. Fine ballast just doesn't look right to me. I think I should of grabbed some medium. I feel for you N/z scale guys that use the fine. I couldn't keep it in one place. Floated like crazy.
I created a foam hill for my "country house" I'll cover the imperfections with plaster cloth. I'll need to create a sidewalk and driveway. I think the driveway will be an old gravel road. I think the sidewalk will be covered with snow for the most part. I purchased a 50's chevy pickup with headlights. Also have an old gas driveway lamp to install.
Pictures to come soon.
jflessne
165
Hot Arizona
www.azlivewire.com
[LEFT said:
shaygetz[/left]]But not too small for two trolleys...:thumb:
I actually just purchased a 0-4-0 steamer to run around it. We will see how it works out.
I plan to cover the roof with snow. But I did do a light wash on the shingles in case I wanted some it exposed. What do you suggest for the body of the house. Since it's winter I noticed a window opened on the second floor. :) A little styrene it's closed.
I suspect it's going to be a problem. I ran a test diesel over it and it seemed fine. I think what your seeing is my newbie Its my attempt at laying flex track. :(
BTW...
twern't ignorin' ya jes ' busy settin ' mine up, too.:thumb:​
It's hard sometimes when you post something. And your not 100% happy with. The worst is when no one responds. LOL
oldtanker
771
West central Mn
Hey it's for Christmas and a learning experance.....I don't see anything wrong with it and am planning to do something similar next year in N scale for our small 4' tree. You gave me the idea!
I'm my own worst critic!
Rick
ocalicreek
824
Puyallup, WA
groups.yahoo.com
Okay...best thing for getting the alcohol or 'wet' water down onto freshly poured and shaped balast is an atomizer sprayer. Just look in the travel toiletries section of any Wally World and find the little plastic travel bottles, OR in the garden section for a nice plant mister. Buy one from the dollar store at your own risk...I speak from experience here, they are prone to freeze up or not give you a reliable, fine mist spray.
The whole idea is to gradually soak the balast with that wet water or alcohol so that your glue/water mix can be applied with an eye dropper, old Elmers or Sobo bottle, etc. at a faster rate without disturbing all the hard work that went into spreading out that balast so neatly to begin with.
But let me encourage you to keep working on this project and hang in there! Make sure the train runs reliably all the time or it will quickly become a static display...neat, but far less magical around the tree. With HO that can be a difficulty due to dust, carpet fibers, cat hair, tree needles (real or fake), etc. fouling the track and causing derailments. SO you want to have super bullet-proof track to begin with to make trouble-shooting a derailment a simple matter of finding the culprit foreign item and removing it, not having to kneel beneath the tree and solder and cuss at the track to get it back into place.
I think the plan you've selected is nice, with the crossing. Hide it in back...even in a tunnel or behind a big present so that each time the train comes around it is on a different track. Cool effect. Keep us posted on your progress! Looking good!
Galen
ocalicreek
824
Puyallup, WA
groups.yahoo.com
As for the house...check out pictures of real homes in the snow to see where it accumulates on the walls, eaves, window sills, etc.
And here's a crazy idea...find one of those fiber optic trees that change colors and shimmer...you know the ones that are green but have the fiber optic cabling embedded in them somehow. Anyway, pull out the fiber optic guts and drill many many holes in the house, then feed the fiber optics into those holes and voila - Xmas lights! Could be really neat in some lichen shrubs around the building...with a good dose of snow on them, of course.
Galen
pgandw
1,002
jflessne said:
Well this layout is coming along. I'm using it to prep for my full size layout. Some things I have learned and have questions about. I promised I'll post pictures once I get my camera problems worked out.
I purchased and used Flextrack for the entire layout. It was difficult to place the flex track and make it come out the same radius continuously. I think I read a suggestion about using a yard stick to draw lines as a guide. (I'll try that next time.)
If you are using Atlas flex track, the natural spring makes it difficult to get a constant radius, and smooth joints where the track is curved.
Guidelines drawn will help. Cardboard templates cut to your desired radius can work, too. Another solution is the radius gauges made by RibbonRail. They fit between the rails and hold the track at a fixed radius.
To get around the kinks at the track joints, most solder the track joint and rail joiner together while the track is still straight. This strengthens the joint so the thin sheet metal rail joiner doesn't have to hold the two rails in perfect alignment by itself. Then bend the combined flex track sections to your desired curve.
my thoughts, your choices
jflessne
165
Hot Arizona
www.azlivewire.com
I spent a lot of time cleaning up all the ballast that ended up the top of the rails. Doesn't seem to affect running trains it just looks terrible to me. I'm convinced I used the wrong sized ballast. Oh well. It's not going to end up under the tree this year because I just couldn't get it done in time. :(
I'm still working on some elevation variations in the foam. I'm waiting on some tunnel portals etc.
Hopefully pictures soon.
