slipper clutch
Discussion in 'RC Offroad Forum' started by TAS51E, Feb 1, 2006.
  1. TAS51E
    TAS51E New Member
    i bought a second hand nitro rustler and the slipper clutch is giving me the #@$% there another spur gear i can put on that doesn't require a slipper clutch.
  2. nitrosniffer
    nitrosniffer New Member
    I run robinson racing slippers, your stock slipper has 6 pegs in it, if you replace the 6 pegs with 12 your problems will more than likely be solved forever, the 12 pegs will cost you less than 2 bucks. With the Robinson racing setup you can go to a fiber washer on each side of it on never have to touch it again.
