Skynet paper HK tank images
Discussion in 'Science Fiction & Fantasy' started by ISNJH, Nov 1, 2008.
  1. ISNJH
    ISNJH New Member
  2. Nothing
    Nothing Longtime Member
    very nice. thanks for sharing.
    ARMORMAN Guest
    well done!
  4. Kjev
    Kjev Member
    Any plans for the aerial hunter?
    ARMORMAN Guest
  6. ISNJH
    ISNJH New Member
    Nice model, did you do the 3D mesh?
  7. Kjev
    Kjev Member
    So, uh. . . . Armorman?
  8. Stev0
    Stev0 Active Member
    I would have to say that the mesh is way too dense.
  9. Not at 3 foot:mrgreen:
    ARMORMAN Guest
    Yes, it's my mesh.
    I have ways of working around the density.
    I still have to complete the Talon before I move to this.
  11. Kjev
    Kjev Member
    Exactly HOW are you supposed to have terabyte upon terabyte of unfinished projects if you doggedly insist on finishing one before finishing another? And what about job security man? If you finish them all, what will you do for entertainment?:mrgreen:
    In the mean time, I have no idea how to tell the density of it from the pictures you've got, but it looks awesome!
    ARMORMAN Guest
    ISNJH, sorry for hijacking the thread. Is there any progress and are you going to release it?
  13. ISNJH
    ISNJH New Member
    No problem Armorman. well the kit as it stand is a mess and needs to be completed redone. I learned alot from building the prototype model. but the model need redone and made easier to build. one thing is my model I did in 3D had a lot of errors in it that made unfolding and setting up a real pain. my goal is to make a model that can be easilier built and would be good for use in table top war gaming. Armorman you would not happen to have a 3D HK tank to go along with the HK air unit would you? if you did maybe I could use that as a basis to work from just asking :)
    ARMORMAN Guest
    Sorry, no. It was on my list, but as with many things, it was back burnered.
    All I can tell you is make the 3D model with unfolding in mind. That is, make it as if it was paper sheets, then you should end up with a model with fewer fiddly bits.
