Sketchup questions.
Discussion in 'Gallery & Designs' started by Mousemuffins1, Apr 13, 2009.
  1. Mousemuffins1
    Mousemuffins1 Member
    I have a design in sketchup that I'm trying to turn into a printable format. I have two questions.
    1: How to I make the unfold plugin unfold in the direction I want it to? sometimes it works, and then it will fold in onto itself, or just randomly deposit bits everywhere. Is there a way to control this?
    2: How do I print out my unfolded piece, turning it from a 3d section floating in cyberspace, to a flat, corectly sized outline on a piece of paper.
    It's probably something obvious, but I just cant seem to get there.:confused:
    Thanks all.
  2. ltla9000311
    ltla9000311 Member
    Hey mouse,
    Are you using a plugin with sketchup? If it's the one I'm thinking of, it didn't work the way I wanted it to. Very finicky.
    If you're using pep try this:
    Try making sure your parts are not "grouped" when you export it to a .kmz file. It seems that pep doesn't like the to unfold when things are "grouped" or made into a "component". That has solved most of the problems for me.
