josve
The construction of the narrowest leading wheels.
I start with the centerpart made of two circles glued to 1mm karton and the paperstrip around.A lot of cutting on the holes in the sides here..
Next is the outer parts, and the inside skin on them.Also a lot of cutting here.
The parts are glued together so the holes fit all around.
Next is to put on the two strips to make the upper part of the "rubber"
The sides.
This part is made of the outer circle and the centerpart.Also some cutting here to be done....
Here I have put on the outer ring and cut out the parts on the centerpiece.
I have also played a bit with a weathering set from Tamiya on the tyres.
One side done
The centernut
And the "leafes" are cutted out and will be glued onto the centerpart.
Front side done and the leafes for the bacside and the centerpart is in turn.
Done
Hmmmm....I also notice I have forgotten a part....
There will be NO price to the finder
The sides.
One side done
The centernut
Done
