hello!
i'm curious if anyone here has tried to make this stuff before, and if they have advise. i'm scratch building a catenary system that closely remsembles that of the Northeast Corridor.
i have the supplies for building the catenary poles and bridges, but i am haveing an issue with the catenary wire itself
i went to a nearby hobby store and bought some .032 music wire to make the trolley wire itself.
my basic plan is to put 2 pieces of wire clsoe to each other, held together by a template i made, and solder them together every 2 inches, to simulate the look of the catenary wire.
the problem is that the solder would not cling to the music wire! at first i thoguht it was corrosion on the wire that causes the problem. i took steal wool and cleaned them until they where much shinier. unfortunately that didn't solve the problem. i tried and tried, but as i moved down the wire, previously hardened piced fell off, or i could not get the solder to connect with the other side, most of teh time the solder stuck to the soldering gun
ironicly the first 3 solder drops stayed, but according to my dad they where "barely holding on at all"
my dad tried silver solder... which worked slight better, but not good enough. my dad's next suggestion was to get some flux. until i get flux, i'd also liek to ehre your suggestions, cause this is something entirely new to me. i also burn my thumb with the iron, so now i have to get this project done, to make that worth it.
chris
chris
