Scratchbashin' DPM's "Freight House
Discussion in 'Scratchin' & Bashin'' started by Casey Feedwater, Nov 25, 2003.
  1. Back in early June, I began a "scratchbash" project using DPM's ubiquitous HO scale Freight House kit. The object of the project was to see if I could take an ordinary kit, one which isn't normally considered to be "finescale," and turn it into something that approached "finescale" when finished.
    Since this was a "weekends-only" project, it took me a little over 5 months to complete it. And along the way, I changed my mind several times about certain aspects of the whole thing. So what I wound up with was a kitbashed version of DPM's kit, a scratchbuilt structure to go with it, and a diorama that will go on my layout when I get the benchwork and track finished for a certain area.
    This is what I began with. As can be seen in the third photo, my first step was to replace the foundation.
    In quick summary, I replaced the foundation with a scratchbuilt, hand carved stone foundation, bricked over the office door and window on the back wall with brick wall "plugs," boarded over a side window, added the attached shed, installed rafters, purlins, and tarpaper for the roof, added door pulls to the freight doors, and scratchbuilt the freight dock.
    The second structure was completely scratchbuilt from stripwood. The only commercial components are the two small door castings, the two large windows (Grandt Line engine house windows) and the two small office windows (courtesy Brett Gallant at Sierra West.)
    I decided to wait until the diorama is installed on my layout to finish the scenery and detailing. That's why there's just a dab of ground foam and a few unpainted castings in place.
    And that's that.
    Here are some links for anyone who would like to see additional photos.
  2. Tyson Rayles
    Tyson Rayles Active Member
    Many, many, many thumbs up Mike! :thumb: :thumb: :thumb:
    :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
  3. Ralph
    Ralph's for fun!
    Mission accomplished Casey! The origins of this structure wouldn't be immediately obvious at all. You've given it fine scale quality and individual character. Adding the strip wood structure really enhances the scene! Beautiful work!
  4. Arlaghan
    Arlaghan Member
    Very fine looking modeling indeed! :eek: ;) :thumb:
  5. Lighthorseman
    Lighthorseman Active Member
    :eek: Simply outSTANDing! :eek:
  6. Gary Pfeil
    Gary Pfeil Active Member
    Man thats nice! The scene looks great.
  7. Blake
    Blake Member
    I can't say that I am surprised as you always produce fantastic work. You are not a modeler Casey, you are an artist!!
  8. Tad
    Tad Member
    Very nice, nice photography, too.
  9. Fred_M
    Fred_M Guest
    Fantastic work. Is the wood structure wood, and if it is how did you get that color in the wood? DASH
  10. Thanks for the nice comments, everyone. :)
    Dash, yes, that is real wood. The entire structure is built from scale stripwood. I started with 4x4 framing over a simple template that I drew. As for the color of the wood, it's a multi-step process. In a nutshell, however, I prestain the wood in a water-based acrylic stain that I make with inexpensive craft paints. After the wood has dried for a couple of days, I scribe it for grain. Finally, in this particular case, I semi-dry brushed it with Apple Barrel's "Country Gray" and followed that with a wash of black alcohol. I followed a similar process for the window frames and the horizontal bracing on the loading dock.
    If you want to read the specific details of how these structures were built and painted, here is a link to an on-going discussion about it (and several other projects by other folks.) I'm sure you will recognize some prominent Gauger's names in the thread and see some fantastic work done by them also. :thumb:
  11. George D
    George D Member
    Nice work. I like the way you added the second structure and the connecting passageway - it adds a lot of character to it.
  12. Thanks, George.
  13. interurban
    interurban Active Member
    A wonderful job Casy!!:D
  14. Matthyro
    Matthyro Will always be re-membered
    Excellent as always Casey. Beautiful workmanship.
  15. Thanks, guys. It was fun trying to do something different with a kit that has been well established for several years in the HO market. :p
  16. shamus
    shamus Registered Member
    Terrific scratchbuilt model Mike, you do produce some excellent masterpieces.
  17. Many thanks, Paul. Your compliment is truly appreciated. :)
