scissors or knife?
Discussion in 'General Card Modeling' started by mapuc, Nov 24, 2004.
  1. wunwinglow
    wunwinglow Active Member
    I too use the Olfa circle cutter, but I modified it slightly. The beam is a sloppy fit into the spike bit, so I glued a strip of 0.5mm plastic card to the top surface of the beam. Fit is much more smooth now, and it is easy to set it accurately. Next project will be to fit it with a screw adjuster....
    Tim P
  2. david n
    david n New Member
    If anyone is still looking for the little Fiskars Micro Shears, Wal Mart (in the US) sells them in the sewing section. Target has them also, oddly I found them in the gardening section!?!
    They run about $10 but are well worth it. I use them for non straight edge cuts all the time. Also great for decals on plastic kits...
