Scenic Ridge Question
mistressmotorsp
50
SoCal
Hi. I asked this on another forum but couldn't get an answer. Does anyone know what the % incline is for the risers that come with the Woodland Scenics Scenic Ridge kit? I was thinking of using the kit as the base for my new layout. Even though the trackplan is a bit different, many of the scenery elements are the same. My trackplan needs mostly 2% and some 3% grades, so I was wondering what the kit had versus what I still needed to buy. If no one knows I certainly can just measure once the kit arrives. Thanks for any help.
Mike
mistressmotorsp
50
SoCal
Thanks for the help. I wonder if I can use a table saw to cut a 4% grade into a pair of 2%'s. Probably not neatly, but it would be fun to try.
SR39
37
Upstate, SC
I am doing the Scenic Ridge and the grade is 4%. I changed it by extending the risers almost to the lower tunnel portal and the grade is now about 2 1/2% Retroguy is the authority on Scenic Ridge. He has given me a lost of help. Search under Scenic Ridge and you will find his posts plus pics of his Scenic Ridge.
Jim
