Scanner Pro-97 Help
Discussion in 'Getting Started' started by nolatron, Apr 27, 2007.
  1. nolatron
    nolatron Member
    Hi folks,
    I recently got a Pro-97 off ebay and having reception problems with it. Hope someone a little more familiar with the device may offer some assistance.
    Ok, so I'd have to say there's something up with the Pro-97.
    First off, here's clips I recorded on my Uniden BC92XLT:
    Now here's what the Pro-97 is hearing:
    These were recorded on the same antenna, a traintenna mounted at about 22'. Only changed the antenna cable from unit to the other. So it's certainly something with the pro-97.
    Then it gets even weirder. The Pro-97 is picking up what sounds like a TV or Radio station on 161.445 AAR 89 Palestine South - Navasota - Bryan - Eureka Road Channel here in Houston, TX.
    I reset the Pro-97, in case the previous owner had some wierd settings on it, but no change on the reception.
    Any ideas to try?
  2. chessie4155
    chessie4155 Active Member
    I think Radio Shack sells those, you could take it to them , if you have one localy, and see if they can check it out for you...
