savage s25
Discussion in 'RC Offroad Forum' started by cford71177, Feb 20, 2006.
  1. cford71177
    cford71177 New Member
    i am new in this hobby i have ran about ten tanks of gas well yesterday i was riding and i noticed the front wheels were spinng faster then the back i had a decent amount of grass build up on the back axles i did clean them off but now the front is still grabbing did i break something any help thanx chris
  2. cford71177
    i was cheking it out again and the front tires will burn out but the back wont spin any soultions does anyone no
  3. cford71177
    i found the prob i blew the diff gears but i wanna no if they make an upgrade instead of the plastic ones thanx
  4. mavrick0
    mavrick0 Member
    The diff gears are hardend metal not plastic. The only plastic part is the diff case and yes you can buy aluminum diff cases. Also depending if the savage is an older model it might only have 2 spider gears where the new truck use 4 for added strength. If you only have 2 spiders get the kit from hpi that gives you the 4 spiders and new cross pins.
