SAVAGE HELP PLEASE
Discussion in 'RC Offroad Forum' started by SAVAGEBOY, Jan 17, 2006.
  1. SAVAGEBOY
    SAVAGEBOY New Member
    CAN SOMBODY PLEASE HELP ME. ON MY SAVAGE MY BRAKE WONT WORK WHEN I HIT THEM, SO I CANT STOP..... THATS FOR STARTERS..... MY TRUCK STARTS ALRIGHT,BUT IT WILL EITHER JUST SHUT OFF OR IF I GIVE IT ANY GAS AT ALL IT WILL SHUT OFF.....SOME TIMES IT ACUALLY STAYS RUNNING AND IT WILL GO WILL THE THROTLE DIAL ALL THE WAY DOWN Y??? I HAVE NO BRAKES SO I HAFT TO STOP IT WITH MY FOOT........SOMEBODY PLEASE HELP?!?!?!?!?!?!?!?!?!???
  2. stolenbikes
    stolenbikes New Member
    he im not sure about your breaks but your glow plug is probly broke in so tune you carb
    i hope this helps but i would go to a hobbie shop about the brakes cuz my gt brake what bad and i drove and drove for a long time and then ended up crashing and breaking the front wheel. lol
  3. stolenbikes
    be side the problem you having how has it been. i am thinking about getting one.
  4. cford71177
    cford71177 New Member
    have u tried adjusting them if your facing the front of the truck it will be the drivers side turn it clockwise to tighten its a small plastic screw my savage stops on a dime on asphalt alittle slower on dirt
  5. mavrick0
    mavrick0 Member
    The other issue depending on which savage you bought is the stock brakes suck. If you have the fiber disk with steel pads you want to upgrade to the dual disk kit which uses 2 steel rotors and 3 steel pads with friction material. As for the engine issues sounds like you need to tune it.
