Saturn 5 build
9,549
This is one awesome model!!
sat-5-011-jpg.149383
Reactions: lyter1958
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
Have you thought about maybe cutting off the flag panel section and replacing it with a "blank" panel, and insert a flag panel into the section below? I think if you print a replacement flag panel on thinner paper you could glue it over and no one would notice...?
ya, i thought of it but it's done and i like it where it's at. i gotta be different:)
X Sonic
15
Ironically, I had a big problem with that section too. I glued it on upside down, so the panel lines didn't match up. I decided to cut it off and glue it on properly, but one segment got wrinkled and looked bad. I printed out a replacement panel on the same weight paper and glued it right over the old one and it turned out pretty well - I can't tell where the replacement is anymore unless I feel along the seams to find one that is raised more than the others
