Saturn 5 build
12,352
Cool progress! Yesterday I was thinking about the F1 engines a lot. I heard that NASA had to re-build the first and second stages of the Saturn V when they wanted to send men to the Moon again (and Mars) because there is nothing more powerful available. In other words, a 50 year old design which is still unsurpassed today. Isn't that incredible? :)
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
and they should. those engines are MONSTERS. just watching the old films of the launch, you can almost feel the power of them.
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
all J2's done except for 1 small part i gotta get ( a 3mm bead). trust me, i looked through out the house but no luck.
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
this is the interstage. i had to cut out 32 of those little rib pieces and my fingers are sore now. the walls on this part are 3 pages thick. just about got it finished today, and i'll have pic's in a day or 2 ..
enjoy
9,549
That is a bit o a simplification. What NASA did was locate an unused, new in the box one, then 3D printed a new one, and fired it. That, is a much bigger feat. The original ones were welded together by hand, the new ones are very smooth, and much stronger. For Solar exploration, a rocket engine that can power up, shut off, and start again is essential. :)
Link = http://3dprint.com/95914/nasa-3d-print-f1-rocket-engine/
Reactions: lyter1958
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
ok guys, interstage is complete. finished the 4 thrusters and placed it on the 1st stage. now onto stage 2
12,352
You are building this monster at lightspeed! Awesome progress. :)
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
Thanks Rhaven, i've thought of that. maybe even giving it to the local school for the science classes. don't know yet but i'll think of something
thanks Revell-Fan, it is coming together fast, the directions are easy to follow. the most time consuming is pre scoring everything ( through trial and error) and cutting the parts out. i get at least 3 to 3 1/2 hours a day to "play". by then these old hands are getting tired.
9,549
It's coming out excellently. I attached a picture below which shows the difference between the hand made combustion chamber, and the 3D printed unit. It is quite astonishing. :)
12,352
:cool:
Do you know what that means? If there are any new paper models of the future new planetary space rockets, they will be much easier to build because they will need fewer parts. It is good to see that the designers have a soft spot for us modelers and save us much building time! :D ;)
