Saab 340 Eerie Eye
shika
248
Rayong, Thailand
[/url][/IMG]Saab 340 Eerie Eye
AEW&C
Royal Thai Air Force
Wing 7 Surathani
Pattern by Jack the paperman
9,549
Looks good, Adjust the Early Warning Radar to look like the picture below, and straighten out the props. If you ever want to make the props look like they are spinning, cut a circle out of thin plastic the diameter being the same as the props length. Apply a shade of gray over all, you should almost not see it, and a little darker o the end, whatever the color of the blade tips are. Then it looks like a plane in flight. The picture below the plane shows the technique. Hard to master, but once you do, quite effective. The once in the picture below is a little too pronounced in my opinion. When I used to fly, you could barely tell the propellor was there, just a very slight grey circular shade, with the tips more pronunced, if the particular plane had painted tips. That is a neat airplane. I hadn't heard of that one before. :)
