S.S. "Californian" 1:400
lehcyfer
283
15
My friend asked me to test build this model.
First thing I've laminated all parts that needed it on 1mm card. They were cut out, their edges treated with cyanoacrylic glue and sanded to high precision
As you can see, the ends - especially overhanged stern - have much more ribs than the flat middle
The skeleton was put together dry
You can see closeups of stern and bow
And finally everything was put together dry to get the idea of how it will look like:
See you next time :)
Reactions: bgt01
9,892
It looks like you are off to a GREAT START!!!
I like the idea of treating the edges with CA glue and then sanding to get that perfect edge. The part that you showed looked like it was professionally cut.
I will be following this thread.
9,549
You will have to be sanding some angles into those ribs especially at the stern. I'm sure you're up to the task! :)
lehcyfer
283
15
Thanks Chris :)
Yes Zathros, I'm surely up to the task ;)
On with the thread:
The skeleton was glued with cyanoacrylic glue, the edges sandpapered again - to get easy flowing lines accomodating to the shape of the plating. Some edges on bow and stern were sharpened - according to the instruction.
Pieces of plating were cut out and retouched:
Pieces of plating are shaped to accomodate to the place they are suppose to take. Then they are glued together on touch using BCG glue - first in the the middle - matching the center marks printed on the parts, then the sides.
A strip is cut away from a piece of cigarette paper, covered with glue and applied on the connection from the inside. After drying it with a hairdryer - a tool I use to dry every single connection which speeds gluing considerably - the line of connection is smoothened down from behind, using a rounded stick - the end of my Olfa AK-3 knife. The line is now smooth and nice.
If pieces are glued at angle, the smoothened connections also take more flowing shape.
Edges which are to be glued together into a sharp edge are sanded sharp using Dremel rotary tool. Such edge is for example on the bow part of the plating
Parts for the stern are cut in half - to facilitate similar sharp edge. This time smoothenigg is done from the colored side because this part of plating is concave. Sides are glued together, forming another short segment of plating.
The bottom plating is assembled into short segments
Short segments are glued together into two main parts - front and back. To the rib where they connect there are glued - from both sides - short strips of thick, soft card from a beer pad which are then sanded flush with the rib
The underside of the bottom plating is then profusely covered with the spray glue from underside and glued on the bottom right away, first back, then front - this way the glue sets slower, allowing for fitting.
Closeups
See ya folks ;)
Reactions: zathros and bgt01
lehcyfer
283
15
Thanks Chris - you know I love to share the techniques ;)
Good luck, Inky, I wish you success :)
The build moves on.
The parts for side plating are cut out and retouched.
The same technique as in the bottom is used to assemble the stern hangout. The connection with the side belt is strengthened from behind. The two parts of side belt are connected.
The side plating is ready to be glued on
The stern hangout is glued on. At the bow there is a bit to cut off. The ready bow looks sharp :)
The body is ready.
Reactions: bgt01
9,549
I believe that has to be the finest seamed and glued under belly of any model I have ever seen! It is flawless! :)
lehcyfer
283
15
Thank you Zathros, Micah. It was flawless until it slipped out of my hands and have fallen to the floor. I repaired slight damage to the bow and caved in place in bottom side, but it's not flawless anymore :(
Now it's time to start filling white spaces on board ;)
Skeleton of the middle island is glued on the board with drops of cyanoacrylic glue, together with additional strips of card added for easier and more precise gluing of the sides of island. Dry test with a side element shows that it works as intended.
There are many ways to glue box-like elements. One of them is to cut the box apart and glue the pieces separately. It is shown here with the sides of the middle island. They are cut into separate facets, the edges are sharpened so that when glued together they will form a sharp edge. The niches are not cut into pieces - instead their lines are cut slightly from the back - the bend will be sharp but there's no need to glue separate pieces :) The cut and sharpened pieces are glued together on touch, forming one piece
Which is then glued around the laminated top of the island - when the ends meet, there's a tiny excess to cut away. The island is checked for fit and glued onto the skeleton.
Another way of gluing boxes is based on making the lines of bending thinner from behind which allows for sharp edges without cutting the walls of box apart - much faster method but requiring practice and feel for the material - a bit too deep cut and the part can be damaged.
Before cutting a part out there are markings made by doing small cuts with the knife from the front - showing where is the line of bending after the card is turned over. On both sides of the line of bending, from the back, there are cut (not through) two lines. The distance between them depends on the thickness of the card (a matter of testing). Then paper is scratched out from between the lines using the tip of the knife. Then the part is cut out - in this case the sides of the base of the stern bridge. Its skeleton is fit to the part and finally the element is assembled. A tip - the bent wall is the one without portholes - it's 1mm wider than the opposite straight wall.
In most cases in this model I will be using the second method. That's how was made this funnel deck
Side skylights and top skylight of the funnel deck are thinned from behind, cut out, glued together
and attached to the funnel deck - together with a hatchway. The resulting structure is fitted dry on the middle deck.
The base of the stern bridge is similarly placed on the stern deck. And last photo shows both structures and the middle deck on one picture.
Reactions: zathros
lehcyfer
283
15
Continuing covering bigger white spots
Covers for the cargo holds. The edges of the white places on the deck were blackened to avoid white lines showing.
White boxes placed on the stern bridge are glued without the bottom as it is unnecessary and allows for cleaner fitting to the deck.
The main bridge is glued up, and there are railings and skylights added.
The main and stern bridges together
How it all looks together - with additional skylights on the middle deck.
9,549
The deck work is very nice and clean. The ship is really coming to life! :)
lehcyfer
283
15
Thank you Micah, Rogerio, Chris, Zathros. I can see that neatness and crispness is in high demand ;)
Something other was in high demand in that historic night...
Boat stands, parts of the boats, shaping the body
Completed boat
