russian heavy tank IS-3 (MM)
Discussion in 'Armory & Military' started by joryyys, Sep 8, 2007.
  1. joryyys
    joryyys Member
    I've started this model. 1st advice for ones who'll build this model - DON'T biuld this model! Better take MODELIK IS-2.
    Good luck!
  2. Amazyah
    Amazyah Senior Member
    Can you elaborate for us!
    What exactly is the problem with it? Bad fit?
  3. Dragos
    Dragos Active Member
    Good question. What is the problem?:eek:
    I'm also courious:confused:
  5. joryyys
    joryyys Member
    Bad paper, bad instructions, bad fitting... I'll try to do the best I can.
  6. nibel
    nibel Member
    That is what will challenge you as modeler :mrgreen: Good luck and hope cansee how is your progress
