Russian armor
Discussion in 'Internet Finds' started by Vladimir, Nov 15, 2007.
  1. Vladimir
    Vladimir New Member
    Hello all members!
    I am going to upload some models of Russian armor. The first is KV-1 heavy WWII tank and it's variants. Then if you like MLRS "Smerch" SA missile S300.
    So look to download area.
  2. cgutzmer
    cgutzmer Guest
    Thanks! And welcome t the site - what a super way to introduce yourself :D
  3. cgutzmer
    cgutzmer Guest
  4. Dragos
    Dragos Active Member
    I like your tanks!!!:thumb::thumb::thumb:
    Thank you! sign1sign1sign1
  5. Stev0
    Stev0 Active Member
    Very nice Vladimir. I think these models are straight forward.
  6. Panzerbeto
    Panzerbeto New Member
    Very nice tiny models
    Those are really pretty ones.
    I wonder if you could reduce the compression of the JPG file, to reduce loss of detail, as I would like to make those in 1/72nd scale!!.
    Any chance of a SCUD-B, as it uses the same 8 wheels carrier????
  7. Vladimir
    Vladimir New Member
    Sorry, but all my models in armor section have the same resolution as the original drawings. I would have to make complete redraw to increase it.
    I am not going to build SCUD because MODELIK already issued this model in 33 scale and it is highly detailed. Maybe in some time I'll try to do OKA (NATO code name Spider) or Iskander - twin missile launcher. But now I have not enough drawings and photos for work. My next plans are Su-24 (Fitter) and Tu-22 (Blinder). I hope you will like them.
  8. 57townsman
    57townsman Member
    Wow a Tu-22 :thumb: Are you planning the early version or the later Tu-22M? I hope it will be the early version although it has a lot of curves to it.
  9. Panzerbeto
    You could try SS-21 Scarab
    Seems very simple and I can send you a high res drawing.
    It's russian name is 9P129 Tochka.
    It has only 6 wheels and seems member from the same family.
    Let me know your e-mail to
    Cheers and keep the good work:thumb:
  10. Vladimir
    Vladimir New Member
    My model of Tu-22RDK is in progress now. It is an early version called in the west Blinder and in Russia "Shilo" (awl) for it's sharp nose. When I finish test assembly I'll publish it. Missile carrier version Tu-22 KD is also planned.
  11. loadmat
    loadmat Member
    What section did you place your KV-1 under?
    Thanks Greg
  12. loadmat
    loadmat Member
    Vladimir -
    I found it.
    Thanks Greg
  13. the4ce
    the4ce Member
    Exelent work!:thumb:
    I love the KV Russian tank:thumb:
    Keep on the good work:thumb:
  14. Fishcarver
    Fishcarver Active Member
    Vladimir: Nice Models!
    What scale are these?
  15. Vladimir
    Vladimir New Member
    about scale of KV
    I think there must be scale line. I'm to buisy now, sorry, but I think there are some dimensions on the drawings which will help you to adjust your favorite scale. If not, send me a private message.
