running on sand
Discussion in 'RC Offroad Forum' started by Bloobert28, Feb 13, 2005.
Thread Status:
  1. Bloobert28
    Bloobert28 Member
    In summer I'm going to Virgina beach and plan on driving my envader. What things should i do and buy to get ready for this. I already got a motor saver air filter.
  2. dj6666969
    dj6666969 Active Member
    buy some sand paw's (tires)
  3. Bloobert28
    Bloobert28 Member
    I already have some thanks
    Also should i seal my diff?
  4. dj6666969
    it is a Evader right? the diff should be fine because it is housed in the tranny case where it is protected.
  5. Bloobert28
    Bloobert28 Member
  6. Bloobert28
    Bloobert28 Member
    do i need to do anything with my servos ?
  7. gaz_r36
    gaz_r36 Member
    you can put them in a baloon and tie then tnd up and put a tiny hole in so u can still attach your stearing links and stuff
  8. danielh89
    danielh89 Member
    with the baloon idea if you put greas on any holes in the baloon it will make it waterproof aswell
  9. Bloobert28
    Bloobert28 Member
  10. dj6666969
    thing is that the sand will get into the grease just a ballon around the servo and put a zip tie around it that should work just fine!
  11. gaz_r36
    gaz_r36 Member
    i think tower sell a water proof servo so i dont think sand could get in that
  12. Bloobert28
    Bloobert28 Member
    i couldn't find them what are they called
Thread Status:
