runnin in a nitro engine
Discussion in 'RC Onroad Forum' started by gaz_r36, Nov 24, 2004.
Thread Status:
  1. gaz_r36
    gaz_r36 Member
    yo, wots the best way 2 run a .16 nitro engine??
    my bro is gettin a hotbodies tornado
    cheers lads
  2. dj6666969
    dj6666969 Active Member
    I had talked to you on msn about it but im pretty sure every body will say about the same :D
  3. tfhughes_28
    tfhughes_28 Member
    Not all nitro engines have the same break in procedure. It would be best to check the manual if you can. If you can't, then try to contact the manufacturer of the engine and hopefully they can help you out.
  4. rockn82
    rockn82 Marx Brother
    Go with tfhughes he has the right idea. Every engine is different. even at the same alt and break-in and temp you will get different power from the same engine. Follow the manufactures advise. Doing it another way will void your warranty. They test the engines using different break-in procedures and finally choosing the best one that makes the engine last the longest.
Thread Status:
