Rolling Your Own...Rocket Tubes
Discussion in 'Space & Aeronautics' started by wyverns4, May 11, 2006.
  1. Mercsim
    Mercsim Member
    Great idea Tim! Those round tubes have kicked my but too! I'll have to re-try some of my classics, when we get the Capsule project wrapped up (no pun intended). Sharing is so much fun!
    Scott :)
  2. causticphlegm
    causticphlegm Member
    Wow! Thanks for the directions guys. And especially BARX2 for those pics. I've been really bad at the whole rolling tubes deal. I've always managed to put cracks and seams in them.
    Now maybe I can work up enough courage to attempt this:
    :twisted: :twisted: :twisted:
  3. BARX2
    BARX2 Member
    That one's on my long list, too. Got a few more I need to do before that, though. Maybe later this year or next year. I will do the Energiya-M before that one, though.
  4. George B
    George B Senior Member
    Rolling tubes
    I've started rolling tubes for my LUT project. It requires over 122 individually rolled 1/4" tubes. I had to come up with a way to get consistent results so this is what I came up with.
    I made a "master" tube having an ID equal to the OD of the needed tube. After rolling the needed tube around a dowel I applied the glue to the seam then inserted it into the master tube. I inserted the dowel again and rolled it out then removed the perfectly round tube. Works great with consistent results!
  5. Jim Krauzlis
    Jim Krauzlis Active Member
    Excellent tips, guys!
    Barx, that picture sequence explains how you rolled the tubes superbly!
    George, your method for rolling the small diameter tubes is a wonderful idea!
    What a wealth of information found in this thread.
  6. check the thread "rolling tubes" I explain my method which is illustrated there. It is the Scroll method. Take a tube smaller than the diameter you want. tape a piece of paper to it, insert your tube to be and and roll up like a scroll. It will produce a perfect tube every time. Gllue a tab to the back of one side first then when it has ste for awhile when you unroll it you will have to pull it apert slightly simply slip over the tab and it will spring itself into the joint.
  7. Or you could cheat and buy lollypop stick at the craft store. they are paper and can be unrolled to the correct diameter. Just wet them to loosen the glue and unroll to the right size. cut off the excell and walla.
  8. cgutzmer
    cgutzmer Guest
    That will work if you can find a lollipop stick that was rolled up and preprinted with the design of the rocket part you are rolling ;) heh heh
  9. Actually you can still take the printed part and using my "scroll method" roll it onto the lollypop stick.
  10. BARX2
    BARX2 Member
    I added links to my pictures that were lost in the move.
  11. Cut 'n' Paste
    Cut 'n' Paste Ex-pat
    HI all.
    I like Tim Hinds' method - I'll try it soon. For what it's worth, here's a method I've found works fairly well for all kinds of card tubes.
    Find a THIN piece of foam - like a mouse mat, but thinner and firmer if possible. Cut out the part for the tube and lay it face down on the foam. The next step can be either to use a round smooth roller like a pencil, piece of dowel or similar, and roll it over the card carefully - making sure the roller is parallel with the card edge. Alternatively, drag the edge of a metal rule carefully over the card, again making sure to go exactly in the direction of the roll.
    This results in a piece of card that will easily roll without kinks or folds into the tube as required. I found this works pretty well if you're using formers, which I always make with a circle-cutter even if the kit doesn't include them.
    Still, I think Tim's idea is actually better.....
  12. Cut 'n' Paste
    Incidentally, here's a photo of two models I made using the above method to roll the tubes
  13. Cut 'n' Paste
    Er.... that didn't work... Sorry.
  14. dansls1
    dansls1 Member
    Just copy and past the entire line listed as 'BB Code' when looking at the image in the gallery. Or you can use the 'Attachment' option to upload directly while posting.
  15. Cut 'n' Paste
    Thanks. I'll get it right in future.
  16. dansls1
    dansls1 Member
    Oh - and nice looking rockets ;)
  17. dwfunk4475
    dwfunk4475 New Member
    Great thread! I'm in need of a more to scale size and the stuff hanging on the hobby shop wall isn't close enough.
  18. obwand10
    obwand10 New Member
    i use a dowel
  19. Funtime Cthulhu
    Funtime Cthulhu New Member
    Nullmoon's idea has worked best for me. The grain of the paper makes a big difference.
    I tried 3 seperate tube roll attempts for the T. Johnsons Atlas-Centaur. All ended up badly creased and crinkled. I rotated the image 90 degrees and printed it again. That tube rolled flawlessly.
    Hope this helps..
