Rolling, Rolling, Rolling...
Discussion in 'Gallery & Designs' started by bruceuncle, Aug 14, 2008.
  1. bruceuncle
    bruceuncle bruceuncle
    In the course of getting back into this hobby, and in attempting a tiny Gnome engine for my FG Sopwith Tabloid, I found I needed something to tell me how many layers and what lengths were required for rolled tubes.wall1
    Tapping on the calculator all the time got boring. So I used VB6 to throw together the attached little utility to calculate it all for me.
    To use it, unzip and double-click RPLCalc.exe (if you're totally paranoid, virus check it first). If you get messages about not being able to find some files, see the note about VB6 runtime below.
    Follow the instructions on the app's window and click the Calc button. It will then display the total length required and the length of each layer - useful for stepped or tapered rolls.
    The entries are all in mm to three decimal places. Which sounds like massive overkill - but remember you will need to allow for the glue layer and any resulting moisture expansion. You will need a bit of experimentation and comparison of results with the calculator will give you a reasonable figure - about 0.05 mm worked for me with a white 'craft glue'. You need to be very accurate in getting the thickness and inner diameter right. Paper manfacturers' specs are not always that accurate, and wire diameters can be a bit off spec too. Digital calipers are the go, although you can use the 'stack and measure' method to get a reasonable figure (stack 10, 20, 30, etc thicknesses together and measure with a ruler; then divide by 10, 20, 30, etc to get the single thickness).
    The source is included with the EXE for anyone who wants to tinker with the code (I hereby relinquish all rights to this code, etc, etc, blah, blah, blah). Any mods welcome. There's a little error checking and some crude bounding for entered values. Anyone familiar with VB won't find it hard to mod. It uses no ActiveX controls, so should run on most machines. At worst, you might need the VB6 runtime package, which is freely available from Not tested in Vista, but is anyone in their right mind still using Vista? :p
    Hope it might be of use to some of you dedicated scratch builders.
  2. Nothing
    Nothing Longtime Member
    sounds like a great tool! thank you for sharing it.
  3. bruceuncle
    Old programmers can never leave anything alone... Here's V00.02. Just tidied up a bit and no longer needs the Calc button - just scroll the layers.
    For info see original post.
  4. bruceuncle
    Will the correct version please stand up
    :v8: My abject apologies. The above two versions give inaccurate results. My only excuse is that I've had a really bad dose of 'flu for the last month and it obviously affected the grey cells. :razz:
    The one attached here as V00.03 is correct. And I've added a bit to the dislplay to give better information for stepped or tapered rolls. Read the original posts above for more info.
    Again, sorry if the originals didn't work as expected for you.
    ("Every day in every way I will do better and better..." :oops:)
  5. cgutzmer
    cgutzmer Guest
    third tries the charm! right? ;)
