Hi all,
BLOG@PAPERCRAFT: ä»®?組ã¿ç«‹ã¦(11)
⇒It is the head. I attached a clear part (I rode OHP sheets on a paper pattern and cut it)to the frame of the head with double-stick tape first.
(After all some goods pickpocket laying upons are necessary)
Well, I incorporated dome inside part until yesterday, but stuck this one with double-stick tape. The semicircle of the bottom-shaped part opened out then (the photograph lower left), and put the positions of each part together with tweezers from there and adjusted it. (The photograph lower right)
Just cross it in the example, but to be inconspicuous even if some gaps produce it because is the part which is hard to put together very much; a cut end think that feed it, and color coating should do the white color of the department with gray and black. (When I make it with common white paper)
I hope to be able to enjoy the trip that you are happy
