RJR Indoors
johntealn30
23
Oldham
www.rjroriginals.co.uk
Ive not been on here for a while so I thought I'd put on a couple of pictures of my new indoor layout, its 7' long and about 7" wide housed on the window cill of my conservatory
The basic (small) layout
Right end a couple of weeks later (spot the mirror under the bridge ?)
Left end now
View from the centre to left this weekend
picture in the middle yesterday
jcoop1
87
lots of neat things can be done in a small space.
thanks for the pics and keep it up
johntealn30
23
Oldham
wabana kid said:
looks great, I am wondering what you used for track ballast ?:wave:
Because Im using HO track I wanted to loose as much of it as possible. So I laid the track direct onto the base board and then used a tub of fast drying decorators filler (all track joints are soldered).
I filled the sleepers between the rails using a scrap piece of plasticard as a scraper then cut the profile of the ballast shape into another piece of plasticard and strickled it down the outside of the rail to give an impression of a raised bed.
Once dry I painted everything (baseboard track fillr) with a beige emulsion paint. Next step i used a chocolate coloured emulsion to paint the ballast area, A bit of green in speckles using the end of a stiff brush for weeds. When dry I dry brushed with black to add some depth / texture highlight. Last step gloss black enamel for oil stains.
Jim Krause
1,270
Polson, MT
Great job. You have given some inspiration for my dormant On30 trains that are sitting idly on a shelf. Thanks for the pictures. As an aside, I had a Landrover like that one on the flatcar when I lived in Saudi Arabia.
RailRon
1,602
Trimbach, Switzerland
A beautiful example what can be done in a small space! And your landscaping techniques are just great! :thumb::thumb::thumb:
Is the little green steamer freelanced or is it a commercial model? (And it is British, I presume... :D)
Ron
johntealn30
23
Oldham
RJR Dockside "johns Quay"
Pictures from this weeks activities
Started to add details into the office block
Then finally decided on a name for the quayside .. original hey
Then the line started getting busy first off a passanger train came through..
Then the event of the week a coaster had to use the quay for temporary docking (my dad has just finished his 1:48 RC boat and came to use my bath for ballast tests)
John
RJR
