Rivets
BillD53A
72
Fort Myers Florida
Tichy Train Group makes rivets, too...they're like little pins; you drill a small hole in the model and glue the rivet in it. Another way would be to use paper, thin styrene, or foil and emboss the rivet heads from the back. Depends on where you are using them.
Here's a URL for a list of Grandt Line's products...its a little out of date, I guess.
http://www.mria.org/companies/Grandt.html
Dont know if Tichy has a website or not. Bill
sumpter250
multiscale modelbuilder
Jan 19, 2002
3,073
Vernon Hills, Illinois
Edavillenut,
I think you've encountered one of the "modeling monsters", how to add rivet detail to an object.
The usual process is to emboss rivets in a wrapper(styrene,brass,or copper sheet), and then apply the wrapper to the form.
The only time I know of, where rivets where applied after the fact, was a model of the Disney version of Capt. Nemo's Nautilus.
This was done, one at a time, using epoxy resin, and a sharp pointed tool.
In the case of styrene, a separate sheet of "rivet detail", with body putty filling in the back side, was made so that any damaged rivets could be replaced by slicing each one off and glueing in place of the damaged one.
Pete
billk
1,116
Marion, IA, USA
Just brainstorming here -- but would a depression, i.e. a hole, "fool the eye" and look like a bump, i.e. a rivet? Might not hold up under close scrutiny, but seems like it would be a lot easier to do!
billk
1,116
Marion, IA, USA
Works for me. What scale, HO? A 1" rivet would be < 1/64", just a fly speck except to a real "rivet counter" (but he could count fly specks instead). What would be more obvious would be any stains left by water leaks, etc. around the rivets.
Gary Pfeil
2,510
Boonton NJ
An O scale foreground model would be a good place to use individual rivits cut from a sprue as mentioned previously. Drilling all the holes evenly spaced would be time consuming but doable. An alternative also mentioned above is to emboss rivits from the backside of a wrapper. Thin brass sheet embosses well. Place it on a piece of pine and use a ponce wheel to do the embossing. Micro Mark has a 3 piece poncewheel set. One of them should have spacing you find acceptable. Careful drybrushing will really make them pop out. Post a photo when you're finished, o.k.?
Gary
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
rivet, rivet
Edavillenut:
I don't do rivets myself, but I can suggest two ways:
1) put them on a wrapper. the old classic method is to use a clock gear, but these are now collector's items. The ponce wheel from the sewing shop is a possible replacement; just have to get one with the right spacing. You'll need a thin piece of plastic for the wrapperand a slightly yielding surface to put the material on.
2) separate rivets. same method but after you emboss the rivets in the plastic, turn it over and shave them off, them glue them to the tank. Need lots of patience for this one.
I worked a demonstation table next to a Master and he was putting rivets in a plastic car by drilling holes, gluing in a bit of plastic rod and cutting it off with a little bit sticking out. Bit difficult with plastic pipe.
We went to edaville some years ago. What's left at the cranberry bog now?
Edavillenut
184
pepperell, ma
www.lighthousehobbies.com
edaville.
the 4 steam locomotives are gone. they were sold in 1992 when edaville went bankrupt they are now up in portland ant the maine narrow gauge railroad. the still have diesle #2 and the bought a british hudswell clarke 0-6-0 (which i am also making a model of) most of the original buildings are gone. the machine shop was torn down this past winter. oceanspray still grows most of its cranberries in the bogs. edaville is working on rebuilding the place. Slowly.
the thing with the pounc whell works great. my mother has one she uses for soweing and i tried it on a peice of scrap sheet brass and i really like how it turned out. now i just have to buy the brass that i will use for the wraper and "rivet it" :D and build the cement block base. now i just have to find some thing to make the base out of:mad:
