reverse look, but no loop
nolatron
716
Katy, TX
railroad.sodh.net
I'm looking into setting up the same thing pretty much with my DCC layout. I don't have enought room to add a reverse loop or wye, so a simple 'crossover' might do the trick if it'll work with the proper wiring with an auto reverser like this.
AR1 Auto Reversing Controller
http://digitrax.com/prd_powerman_ar1.php
Here's a diagram as well. Same type of setup.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
If there are no further complications (yards, passing sidings), you will need to insulate a section at least a train length long, one end will be at BOTH ends of the lower switch (the part past the frog) and the other end somewhere around the loop before it gets to the other switch. This loop will not be connected directly to the bus wires but to the reverse loop module which is then connected to the bus wires.
When you go into the reversing section, the module will flip the "polarity" to eliminate any short circuit. When you go out again, it will flip the "polarity" the other way.
If you decide to put a crossover in the other way, you will need another block or a slightly different arrangement.
colin
22
canada
reverse loop
so am i correct in saying that the crossover (the part in red in nolatron's diagram) has to be a train length long. so this would not work for two tracks side by side. (the dogbone) unless the section of crossover track was about 6 ft long?
Gary Pfeil
2,510
Boonton NJ
daboonk, what you've drawn is basically what my layout is, in my case the two parallel tracks are pretty long and there are several sets of crossovers. If you look at the wiring suggested by Railway Bob, you will note he connected both "north" rails to one bus and both "south" rails to the other. This makes the crossover no problem electrically. And is the way I wired mine and the way I tried to descibe in one of my earlier posts. However, the two turnback curves have to be isolated on both rails if you use this method, and each is a reverse block. I feel this is the best way to proceed. Yes, you have two reverse blocks, requiring either two reverse modules or one reverse module and the stipulation that you only enter/exit one reverse block ata time. If you don't wan the restriction of only being able to enter/exit one reverse block at a time, and don't want to buy two reverse modules, then do as David mentioned and make one reverse block as he described. If you do this, do not wire the two parallel tracks as Railway Bob suggested, wire them the same way you would have done with DC, that is, opposite polarities. This way the return curves are not reverse blocks.
Gary
60103
Pooh Bah
Mar 25, 2002
4,754
Colin: the crossover does not have to be a train length. It is the part starting in the middle of the crossover, going around the balloon loop and stopping short of the other turnout that we're talking about. Requires double gaps (both rails) between the turnouts of the crossover and just beyond the straight leg of the turnouts at the frog end.
Gary Pfeil
2,510
Boonton NJ
To clarify Davids accurate answewr, the crossover doesn't have to be a trainlength long, but a reverse block does, which is why he descibed the block as he did originally. The reason it needs to be a train long is that metal wheels crossing the gaps at both ends at the same time is a bad thing. However, I believe there is one auto reverser that does not require a train length block, that is Loys Toys unit. Unfortunately, I don't use them and have no idea how it is they work, or what other requirement they may have. You may want to check his website, ought to be www.loystoys.com
Gary
Dansco
101
Sorry, I just don't see the reverse loop!
Out side rail of the inner loop is connected to the outside rail of the outer loop, thus outside is always outside, inside is always inside.
I created a simplified version of your layout in RTS, good for checking for short circuits.
The first image shows the cross over is NOT a short, therefore does not require any reversing module.
The second image shows a balloon loop to demonstrate where an auto reversing module would be needed.
Thanks
Dansco
Dansco
101
Lol, I just noticed I replied to a three year old thread.. whops.
Maybe someone will find it useful anyway.
Thanks
Dansco
