replacing light bulbs on an Atlas GP-30
sputnik
38
bluecreekrr.home.att.net
Actually, the body and "nose" are cast as one piece.
First, the body, walkway, and handrails come off of the frame in one piece (like the Bachman shell off it's frame). Simply work it off, there are no hidden catches or anything, just don't force anything. The fuel tank is it's own piece, and it simply snaps onto the frame, and comes off with a gentle twist. On Atlas/Kato engines, there are no light bulbs, but rather LEDs, which are soldered to small PC boards. Remove those boards by simply pulling them out. If you want to change LED colors, the easiest way is to order PC boards with the desired color (white or golden-white) from the parts section on Atlas' web site.
---jps
PennCentralFan
42
Twin Cities, MN
---jps
Thanks, it worked out okay.
