replacement motor mounts
Discussion in 'FAQs' started by philip, Jan 7, 2004.
  1. philip
    philip Guest
    Does anyone know where I can locate some motor mounts for an old Athearn loco? Walther's is running the blue ink on all motor mounts and my LHS can't seem to locate any. The mount is the two-piece one with 4 dowels that snap into the chassie. Someone said I could silicone the motor in place? With the big merger going on Athearn won't even answer e-mails. The loco is a PA-1. HO 1/87th.
    thanks, philip
  2. Russ Bellinis
    Russ Bellinis Active Member
    Do you have any GAT Shows coming up in your area? There will probably be some vendors there who would have some mounts in stock.
  3. railwaybob
    railwaybob Member
    The Digitrax Athearn wiring harness comes with 2 replacement motor mount halves that have two plastic dowels on each half.
  4. philip
    philip Guest
    Found some today at another LHS. Thanks for the info
  5. Vic
    Vic Active Member
    Phillip, Glad you found the mounts you needed. For future refference you can silicone the motor into the frame. If you do it be sure that the metal contact strip on the bottom of the motor touches the frame so you have electrical continuity. The better solution is to solder a piece of flex wire to the strip, snap it back on the motor and then fill the motor well with the silcone. Then just place the motor in the silicone, push down on it to get the right height and then let every thing dry. After eveything is dry you can drill and tap a 1-72 machine screw into the frame and attach the wire under it for electrical contact. This is also a good way to put true can motors into older Athearn locos.
  6. Russ Bellinis
    One additional trick that one of the members of the modular club I belong to uses is to cut a couple of pieces of 1/4 inch steel round rod the length of the well of the Athearn chassis. Glue the rods in on each side with silicone, and after it sets up, you have a cradle to center the can motor in your chassis.
  7. philip
    philip Guest
    Sounds like some good advise. Got an e-mail from Athearn. Almost fell over dead in my chair. This is the stock# for future reference 84020. Athearn didn't say anything about the part being in stock.
  8. Javern
    Javern New Member
    3M double sided tape works well also
