replacement engine
Discussion in 'RC Offroad Forum' started by antihero2007, Apr 12, 2004.
Thread Status:
  1. antihero2007
    antihero2007 New Member
    is there any replacement engine i can put in my t-maxx 2.5 that will out run a mgt
  2. monsterrcbuilder04
    you could get a .21 conversion or a wasp .18 would probably fit in. i put mine in after the .21 upgrade so im not sure.
  3. mastmec
    mastmec Member
    You should have no problem beating a MGT, is your engine worn out? Any hop ups on the truck? How much do much do you want to spend on an engine?
  4. pimp
    pimp Active Member
    alls u have 2 do is put a novarossi picco engien in it
  5. antihero2007
    the truck is about a week old new air filter is all i have done to it..ill spend any amount i have to on an engine
  6. bigpiper1
    bigpiper1 Member
    get the ofna picco p2. It will cost around 200.00 depending on were you get it from. It is a direct fit to the 2.5 chassis even though it is a .21 motor. It comes with a special motor mount so it will fit.
  7. mastmec
    mastmec Member
    Are you getting beat by one in top end or on a track?
    How did you break in your engine?
  8. antihero2007
    im getting beat by the mgt in top end
  9. dudex
    dudex Member
    just change youre gearing so youi have more top speed then.
  10. antihero2007
    what should i change if i start getting beat on the track
  11. mastmec
    mastmec Member
    Speed should not be a problem on the track, keeping a four wheels planted around corners is, I use thicker oil in the shocks and lower the truck as much as posible. Also drop all the weight you can and rotating mass, ie. reverse and use lighter tire/ rim combos.
    Also the best hop up for the track, a good high torque servo.
Thread Status:
