removing glue
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
I think it would depend on the type of glue. Non-waterproof white or yellow wood glue can be softened with soaking. CA (superglue) can be weakened by freezing. If you used solvent type cement (the kind that "melts" the plastic together) there actually is no "glue" to remove - you will have to cut the pieces apart.
If you can provide a bit more detail, I am sure that someone has a solution for you.
Andrew
