rc helicopter problem?
Discussion in 'RC Aircraft & Watercraft' started by tay n, Apr 26, 2007.
  1. tay n
    tay n New Member
    Dose any one have a problem with there rc helicopter stay still and lifting off high enough ?
  2. steamhead
    steamhead Active Member
  3. Bad_Scorpion
    Bad_Scorpion Member
    Yep same here. But got a new issue and havign issues figuring it out, hit 50% throttle on my walkera 22e and pitches to the right front every time. thinking gyro may be out cause can adjust all over the place and still pitches to the right front when adjust everything to compensate. Any ideas anyone
  4. steamhead
    The piching could be a result of torque from the blades and motor, or from the motor, if the motor is mounted horizontally. If you're using a gyro to control the tail blades, set it to its lowest sensitivity, as it may be over-compensating to blade torque.
  5. paper-toys
    paper-toys FOUNDER OF PAPER-TOYS
    I've been having the same problem when trying to keep the helicopter while lifting off the ground.
  6. Bad_Scorpion
    Bad_Scorpion Member
    Yep same here. And, steamhead thank you. that was what it was. just adjusted, fired it up had to tinker with it couple of times to really fine tune it and then lift off.
  7. steamhead
    Glad I could be of help...
