? radius/track centers
rogerw
1,110
manhattan ks
Any thoughts on will this work out ok? For my double main I am leaning towards 29" radius on outer rails with a 2 1/4 track center clearance. This will make my inner curves 26 3/4 radius . I put my dd40 next to my sd90 on a curve with these spec's and I thinks it looks ok. Clearance seems good allso. Any thoughts ?
N Gauger
1:20.3 Train Addict
Dec 20, 2000
6,732
South Eastern, PA
mywebpages.comcast.net
take the 2 longest cars and or engines and run them (roll for cars) past each other in both directions (Back & forth) on the tracks.... then switch them between the tracks and repeat.
if they all can pass each other in both directions without so much as touching, then you're ok :) :)
