Radius Size?
Discussion in 'FAQs' started by Charles Mark, Mar 5, 2005.
  1. Charles Mark
    Charles Mark Member
    Is 11 inch radius acceptable to use on my layout? I want to make sure most anything will run without problems. Thanks
  2. jon-monon
    jon-monon Active Member
    N scale? Should be OK for diesels.
  3. Charles Mark
    Charles Mark Member
    I plan on running diesels however I have several steam including a Big Boy. Just need to know if I am in trouble trying to run something like that.
  4. MasonJar
    Bigger is always better when it comes to radius...! You can always have parts of the layout "off-limits" to the BigBoy, just as was done in the real world. Let the little 0-6-0 handle the industrial switching on sub-11 inch curves, and let the BigBoy run out on the main with 11/15/?? curves.
  5. brakie
    brakie Active Member
    Charles,I would go with the largest curves possible for long wheel base locos like that Big Boy and long wheel base cars like passenger cars.You won't regret it farther down the line in smooth operation of your trains as they traverse your layout.
  6. spitfire
    spitfire Active Member
    You could always contact the manufacturer and find out what is the minimum radius they recommend.
    Another approach, and IMO the best, is to lay out a test track of the radius you want to use and run your engines thru the curve. This is good for grades as well.
  7. Charles Mark
    Charles Mark Member
    I've decided to widen the one curve that I am concerned about. No track has been laid. I bought another set of WS inclines yesterday so will correct the possible problem now. I'm learning as I build for sure.
  8. ezdays
    ezdays Out AZ way
    Just as a suggestiion, why not set up a test track with the radius you want and see if you can get your loco around it easily.
