Quick relply needed please.
Discussion in 'DCC & Electronics' started by Why me, Aug 22, 2005.
  1. Why me
    Why me Member
    Hi guys just made up my buss lead using(6mm2)for main power and for feeds (0.5 or either 0.7mm2) my Question is as follows do i use the 6mm2 to come from transformer into base and out of base station then use the 0.5or 0.7mme to feed the track ty inadvance.mike
  2. MasonJar
    I am not familiar with the metric measurements for wire, but generally speaking, you need to run the larger wire from the power source (power pack, booster, or whatever you call it) to the (short) feeders that power the rails. If you have a separate command unit (base station?) I am unsure, as I use a Digitrax Zephyr (all-in-one).
    I would guess it would not hurt to use the larger wire to connect the two. What does the manual say?
    I hope that helps - not much of an answer, but I see you are in a hurry... ;)
