Quick Question
Discussion in 'RC Offroad Forum' started by awsomaha, Jul 22, 2004.
Thread Status:
  1. awsomaha
    awsomaha New Member
    Just wondering if you can run your nitro in the rain? Most posts I read don't, but I was just curious as to why not?
  2. rustler
    rustler Member
    i do i mean just as long as you have your cover on and dont go through any big puddles then you will be fine, ive ran it in the rain tons of times and never had a problem
  3. monsterrcbuilder04
    i ran my electric in the rain and i know someone who had theres fully submerged under water.i havnt really takin the nitros in the rain.if an electric can be exposed to it i doubt there is any problem with nitros
  4. redheat
    redheat Member
    Sure you can but before you do I would take the time to water proof your electronics servos and RX box.
  5. monsterrcbuilder04
    ya htat would be a good idea.i dont purposly go into water but sometimes it just happens and it is a pain to ballon hte rx all the time but an the servos you can just put rubber cement on the seams
  6. redheat
    redheat Member
    There you go, spray some WD40 on electrical helps to water proof.
  7. monsterrcbuilder04
    i dont see how wd-40 would help.wouldnt it get everything wet?
  8. redheat
    redheat Member
    Good question WD40 does several things 1-it inhibits rust, 2- it also repells water it has a combination of oils and solvents in it.
  9. monsterrcbuilder04
    oh thats kool.ill try that some time
  10. redheat
    redheat Member
    Right on, RED
  11. It also acts like a grease and sticks
  12. redheat
    redheat Member
    Gotta take the good with the bad , I dont no about you but my stuff gets very dirty after a long day of running them reguardless if I use WD or a dry silicone lube, still requires a good cleaning. Keep in mind when using WD or any lube it doesnt take much to get the job done.
  13. elvisreaks
    elvisreaks New Member
    by the way w/d stands for water displacement, the 40 was thier 4oth try
  14. Justin_E
    Justin_E Member
    stuff always gets dirty. live with it! I think its fun cleaning everything out. It also gives you a chance to check everything out to see if anythings broken.
  15. redheat
    redheat Member
    Depending were you run ,your truck is gonna collect a little dirt so what the heck. Ill keep using it WD-40 that is.
Thread Status:
