question???
Discussion in 'RC Offroad Forum' started by monsterrcbuilder04, Apr 6, 2004.
Thread Status:
  1. monsterrcbuilder04
    i just got back from driving my bandit and when i went full throttle it would go 2 feet and stop. then when i let go of the trigger it would move another 2 feet. sometimes it would run right but then it would go back to skipping. is it the slipper or something else?
  2. mastmec
    mastmec Member
    What kind of speed control do you have?
  3. monsterrcbuilder04
  4. mastmec
    mastmec Member
    What else is going on when this is happening, motor running, noise?
  5. monsterrcbuilder04
    nothing just like the normal noise that it makes
  6. mastmec
    mastmec Member
    When you accelerate it moves 2 ft. if you just hold the throttle, whats happening. Be specific.
  7. monsterrcbuilder04
    well i pull the throttle fully and it moves and stops but as i let go of it it moves a little more. but then i pulled it 3/4 of the way it was fine. also it worked fine in reverse.anything else you need to know
  8. bandit1
    bandit1 Member
    to me it sounds like maybe theres a wierd connection problem with one of the wires on ur ESC. I would just check over any wires and their connections to see if their all good.
  9. monsterrcbuilder04
    ok but its an msc. i'v got to order my esc
  10. mastmec
    mastmec Member
    Your speed control is fried.
  11. monsterrcbuilder04
    ok,i'm going to have to buy a new one. anybody got an esc that they would sell me cheap?
  12. duratraxst1
    duratraxst1 New Member
    it may be the reciever just unplug and plug back in those two cords
  13. monsterrcbuilder04
    i already tried that. it didn't do anything
  14. A J G 3 6 6
    A J G 3 6 6 Member
    this happened to my friend. Theres a connector on the right side of the msc. that may be loose,my friend just put it and secured it back on and it was fine. maybe thats your problem?
  15. ty007cars
    ty007cars Member
    try some new x tals
  16. monsterrcbuilder04
    i'm probably getting an esc
  17. timrock
    timrock Active Member
    you dont know that
  18. timrock
    well if you are getting an ESC get the Streak.it is the best for its cost.only $40
  19. monsterrcbuilder04
    ya thats what i was planing on.THANX
  20. ericmcgehee
    ericmcgehee Member
    it is definately the msc, mine did the same thing. when it turned just right, it would not get a conection.i would almost put money on it.
Thread Status:
