Question:What weight suitable for cardmodelling?
Discussion in 'Tips, Tutorials & Tools' started by PModel Rookie, Mar 7, 2009.
  1. PModel Rookie
    PModel Rookie Member
    Hello,I seem to have problems with choosing weight of papers(Kilos not pounds).Is 100 grams okay?.If not,can someone suggest for me?
    Help is appreciated,
    Please and thanks,
    Edit:Oh,and the size is A4.Thanks.
  2. Dragos
    Dragos Active Member
    I often use 160-180 g/m2 paper , some times even 250 g/m2 , the 120 g/m2 paper I use it for small scales ( 1:120, 1:200 )
  3. PModel Rookie
    For building paragon's model,is 100g paper okay?I keep getting lame and weak models...tried to fly them and for 1 try.....the nose is dump.
  4. cgutzmer
    cgutzmer Guest
    I would use 100-120 gram paper for the majority of the build, use 250 gram for formers and whatnot. If you want to use the same weight for the entire build I would go with 160ish :) Then you can laminate stock together to make the formers :)
  5. Stev0
    Stev0 Active Member
    60lb Cover Stock.
    However that translates.
