Question re: MRC Prodigy Advance
hooknlad
396
Woodbridge, NJ USA
Hello all,
It's been quite some time that I have included any input in "The Gauge" forums. My question for you technical savvy model railers, If I were to purchase the MRC Prodigy Advance dcc controller, Would I be able to upgrade the "current" output from 3.5 amps to roughly 5 or more amps, by utilizing a transformer rated for not more than the output engineered by MRC? I do not have the MRC unit in my posession, Nor do i have the Maximum specs allowable for doing this. I understand that I could purchase a mated power supply for this system, but I'd like the personal modification aspect of this hobby.
Thanking you all in Advance for your constructive criticism and engineered input.
Mike , the instructions say you can boost up to 8 amps using their power station 8. But the PS8 says it connects between the orig. booster and the track.
I can not see why you could not use any 5 amp supply in the same manor as the 3.5 that comes with it. I guess the question would be is 3.5 amps not enough for your size layout? That should easily run 8-10 locos at once.
:wave:
Thanks , Mike
CN1
1,059
I have the PA.
My layout occupies a room 33 feet X 12 feet. I have 7 locomotives including 1 with sound.
I have two cabs (Throttle) and 7 plugin. I haven't notice any change in the "power draw/consumption" with the power supply provided.
There's instruction on how to add more "power" if required. IMHO: I guess you need a pretty big layout and lots of locomotives before it becomes an issue
