Question - OFNA Brakes
Discussion in 'RC Offroad Forum' started by hondaman00, Apr 19, 2004.
Thread Status:
  1. hondaman00
    hondaman00 New Member
    I have an OFNA 9.5 MBX and I cant get the brakes to work. It has "double" brakes - 2 disks for front, 2 for rear. It seems like the servo doesnt have enough power to pull them in. I'm new to nitro and this is my first car. Any help would be appreciated.
  2. mastmec
    mastmec Member
    Make sure your radio is letting the brakes apply, and that it is not trying to bind against the throttle (there should be a spring to compress). Also pull the rods out farther to give your servo more leverage. Also check that your brakes are clean of any oil, dirt.
  3. hondaman00
    I can see the radio is letting the brakes apply, and it doesnt seem to be binding, the spring is there. I will have to check if they are dirty, I was thinking I might have to get a bigger servo to run the throttle/brakes.
  4. mastmec
    mastmec Member
    With the quad brake setup, it doesn't need much in the way of torque to get it to stop.
Thread Status:
