question abput fascia panels.....
Discussion in 'HO Scale Model Trains' started by trainsteve2435, Sep 4, 2004.
  1. hello guys, im going today to get my 1/8" masonite board for my backdrops, and my fascia panels. im gonna have my backdrop boards cut at home depot 2' x8'. is 2' tall enough? also, is it best to wait to cut the fascia panels until i figure out my scenery? any information is gladly welcome. thanks!:wave:
  2. TrainClown
    TrainClown Member
    Hi Steve,
    Sure, you can go ahead and build your back drops. On the yard side it would be ok to make them 24" from the deck, but on the side where you plan to put mountains, you should cheat the 24" boards up a bit and leave a space between the back drop and the deck. Say, 8" to 12" off the deck. This will give you more sky behind your mountains, and, you don't really need a back drop behind/inside the mountains.
    That's what I would do anyway.
    TrainClown ;)
  3. 60103
    The backdrop should go up higher than the tallest visitor. But everything depends on the space you have.
    Front panel should not be cut to shape until you decide on the scenery shape. You could put a low fence in, just to keep stuff on the layout, but it'll be irritating to work over.
  4. thanks guys, for the info. i will wait til i decide on scenery before cutting the fascia panels, as for the backdrops, im currently working on them. only problem im haveing is knowing how much i can bend 1/8" masonite before it snaps. anyone have any ideas? thanks!:wave:
