Question about Pepakura
Discussion in 'Gallery & Designs' started by jparenti, Dec 6, 2006.
  1. jparenti
    jparenti Member
    Not sure how to explain this, but I'll try...
    Is there a way to clear all open edges in Pepakura and specify only your own? Every time I try to specify my own edges to open, the program uses a lot of other edges that I didn't select.
  2. TheWebdude
    TheWebdude Just a Member
    You can specify the edges you wish to cut in the 3D view window 'before' you unfold your model.
  3. Ashrunner
    Ashrunner Member
    You can also join cut parts together if you want them together...if the program will let you. Sometimes it will...sometimes it won't. I am sure there is a reason for it, but I don't know what it is.
  4. barry
    barry Active Member
    Pepakura works on the principle that it knows best then you can alter it but if it says it's going to cut it and you do not want that cut there then you usually need to go back to your drawing. See if the faces are not aligned or something a screen shot would help.
