pvc fit yokomo??
Discussion in 'RC Drifting and Setup' started by DriftFreak, Oct 4, 2005.
  1. DriftFreak
    DriftFreak New Member
    hello rcdrifters, is it possible to get pvc cut down to the size of the rings of the yokomo ZERO ONE Super Drift tires :?: :?:
  2. thunder
    thunder New Member
    i run the rings and love them, but i snap them all the time. they are 5 bucks for eight replacement rings....which can add up! i usually go through that many in a week-end. if anyone has done this pvc ring idea....hook it up...save us some money....drift on people!
  3. SpArKeY_STi
    SpArKeY_STi Member
    It would be extremely hard, but ya. Cause you not only have to cut the PVC to fit the width of the ring, but also diamiter. Meaning you would have to grind down the insides too. Also, it wouldnt work well because if you didnt grind the top down to where they arnt sticking much higher then the orignal rings, you'll have un-even tires and drifts.
    So you could, but it would be a lot of hard work. And PVC isnt not half as forgiving as those plastic rings are. You'd have a heck of a time geting the PVC in those slots.
